G Code, M Code decoding in LabVIEW
Hello All,
I have one CNC machine application, which have 2-axis position control AC Servo Motor. I am using LabVIEW 8.6 for programming and my hardware is NI cRIO-9004 and its chasis is NI 9101. I am generating X us pulse frequency with NI 9476 DO module to run Servo motor.
Now, I have query on G Code M Code Interfacing to LabVIEW. My AutoCAD design generate G code M code file which I want to decode in to LabVIEW and according to it I will give command pulse to both axis AC Servo Motor.
So I am limited to that interfacing of G Code M Code to LabVIEW, So will you please provide me any helpful information to go ahead in this application.
For any additional information you can contact me. Waiting for your valuable reply
Vinal Gandhi, CLA
(6,638 Views)
Hi, I'm also searching for a g code interpreter, did you find any solution for this? I'm using NI-7344 in a 4 axis shaping setup.
(6,326 Views)
