HOw i can control x-y movement using stepper motor
hi
please help me in controlling X-Y translational stage.the movement should be  scaning ie first to left then uu by one unit then to right then up by one unit then left etc
Certified LabVIEW Developer
(4,073 Views)
Accepted by topic author mjaugustin
if you are using an NI motion control device, there is a LabVIEW example shipping with NI-Motion called X-Y Grid Inspection (Template).vi, that does exactly what you are looking for. Please use the example finder to search for this example.
Kind regards,
Jochen Klier
(4,069 Views)
