Help me to plot a 3D graph of aircraft trajetory by using the latitude,longittude and altitude of aircraft
Hi....I am 'anu' from india.
I want to draw 3D plot of aircraft trajetory by using the latitude,longittude and altitude of aircraft is it possible with labview8.5. If you have any similar VI pls share. And is it possible to define a 3D object like aircraft, 2 axis moving objects?   Thanks in Advance
(4,142 Views)
