Help on Old DLL base software and new PMAC Communications Library (Pcomm Server Pro2) conversion
Dear PMAC Experts:
 I am a user of PMAC mini, and we have been used the DLL base software for years. Now I worked on the conversion of new Pcomm Server Pro2, however I discovered there are totally different from the old version DLL(All the functions are not existing in the new COM.) and can not find a way to work on it. Could help review the code below and give me some advices. For detail code information is within the attachment.I would be appreciated if you could also send me a matrix list between old functions and new functions.
(5,352 Views)
Could anyone help me?
(5,343 Views)
I might be able to help... I'm a DTau Field Engineer and have worked with the Pcomm severs old and new... I can get you documentation of the
DLL function call changes and give you other support.
mesposito@deltatau.com
regards,
mike
(5,192 Views)
Mike-
See here.  There was also some offline help with this in which I stressed that he will need to understand the functions to properly transfer them over.  The pcommserver functions are pretty self-explanatory if you understand the PMAC.
Brian
(5,178 Views)
Thanks for the reference to other discussion Brian...  just holler if you and any in the group need some Delta Tau
help... I'm not a NI expert but have worked with DT for 15+ years and can get access to any help you might need.
If I get a NI project I'll know where to come for help as well.
Best Regards,
mike
(5,175 Views)
