How can I add a 'Virtual 7354' device?
We are looking to purchase a PCI-7354 and I noticed that after installing the latest NI-Motion 8.3 that there is no option to add a Virtual 7354 device.  The only options I see are: 7344, 7334, 7358 and 7390.  Can I safely choose the 7358 and integrate agaisnt that without having the change my code when we finally get the 7354 in?
(5,384 Views)
As you have noticed you can only simulate certain devices.  Your idea of simulating the 7358 should work as the only difference between the two devices is one is 4-axis and the other is 8-axis.
Greg H.
(5,376 Views)
