How can I clear the 'Index found' flag using Flexmotion 5.2?
When using the 'find index' VI, the motor doesn't physically stop until a few steps after the index, even with the step rate dropped right down to 5 steps a second. (I have no idea whether this is normal or not - the axis is set to Halt on stop, so I would have thought not, but that's what it's doing!)
This would be ok if I could clear the "index found" flag, drop the step rate down to one a second and do another index find in the opposite direction.
How do I clear the Index found flag?
Mike
Mike Evans
TRW Conekt
N.I. Alliance Member, UK
http://www.Conekt.net
(3,191 Views)
The "index found" flag will be cleared when you start a new flex_find_index command.
(3,191 Views)
