04-13-2007 02:08 PM
04-16-2007 10:16 AM
Yes, it is possible to use your motion card with
LabVIEW. There are several examples that
use motion in the example finder (Help>>Find
Examples). One that would help you get started is called Simple One-Axis Move.vi.
You can set the input
voltage range in the Measurement Automation Explorer. Go to Devices and Interfaces>>NI Motion
Devices>>PCI 73XX>>Axis 1>>ADC settings>>ADC
Channel. Then you can set the voltage range you will be operating in.
Also if you currently have code that you have created in the Motion Assistant then you can generate LabVIEW code by going to Tools>>Generate Code>>LabVIEW diagram. I hope this helps.
Have a great day,
GG
04-20-2007 12:42 PM
04-23-2007 06:56 PM
