Motion Control and Motor Drives
How can i READ Steps / Revolution
I'd like to READ the predefined (in MAX) "Steps per Revolution" (depending on the Board ID and Axes). Is this not possible?
I am using LabView 8.5 with NI-Motion-VIs, where just a LOAD "Steps per Revolution" is available.
(3,414 Views)
Accepted by stefan_hartmann
The NI-Motion API doesn't provide an option to read this value. If you want to have complete control about your motion settings in your application, you should consider loading them in your application.
Kind regards,
Jochen Klier
(3,408 Views)
