How can i put a text inside a motion control?
I'm an italian student and I'm trying the software Motion Control... I want to write with a small milling machine some text. The text is write in a CAD file and when i put this file in Motion Control it doesn't work... Can anyone help me?? Thanks a lot...Smiley Happy
Message Edited by Nixe on 04-10-2008 06:35 PM
(3,509 Views)
Hi Nixe,
sorry for the very late reply. In order to use CAD profiles with Motion boards you can take a look into this document:
Hope this helps,
Fabio
Message Edited by Chuck_81 on 04-24-2008 11:36 AM
Fabio M.
NI
Principal Engineer
(3,442 Views)
Thanks for your answer but i don't find what i search in your link.... I know how I can use motion assistant with simple CAD file (.dxf) but i can't traslate a text inside the CAD file to the motion of axises... There are some errors in the program that it couldn't work... Can you find any solution?? So i've just found another problem: How Can i change all motions speed of shape in motion assistant?
Now i've to change step by step all velocity in all shape, Becouse inside the program who i run there are 51 shape and change all step by step it's comical...Smiley Happy
thanks a lot for your answer Nixe...
I'm sorry for my English...Smiley Sad
(3,439 Views)
