03-08-2005 08:20 AM
03-08-2005 09:04 AM
@Ola.L wrote:
I am running a motor using the PCI 7344 motion control board and a MID-7654 servo with encoder feedback. Running the motor is not a problem but when it has stopped (there is no load) the servo system still puts out a lot of voltage (+-48V) all the time. This makes the motor really hot. I am using very smooth regulator parameters so as far as I know it should´nt have to make these corrections. In the next step there will be a load on the motor so I can´t just disable the axes (which otherwise would be the easiest solution).
//Ola
03-09-2005 06:45 AM
04-08-2005 04:14 AM
04-08-2005 07:07 AM
04-08-2005 07:35 AM
04-12-2005 12:53 AM
04-12-2005 06:12 PM
04-13-2005 01:42 AM
04-13-2005 09:51 AM
