How do I read an analog signal from a PCI-7340?
We are working with an absolute analog encoder that works from 0 to 5 volts. How can I read the analog signal in Labview? (version 8.0)
(3,709 Views)
To read analog values with a PCI-7340 in LabVIEW you should use Enable ADCs.flx and Read ADCs.flx (see screenshot). If you want to use the analog value to close the control loop, please refer to this thread. I have posted there a document that explains all the details, so please make sure to open the attachments.
Jochen Klier
Message Edited by Jochen on 09-14-2007 12:01 PM
(3,708 Views)
Hi thanks for the message. I have made the VI but what is the number of the ai on the PCI-7340?
(3,703 Views)
The number of analog inputs equals the number of axes. So if you have a 4-axis version (7344), you can use 4 AIs, the 2-axis version (7342) provides 2 AIs.
(3,700 Views)
