01-17-2012 11:03 PM
I already have a labview code that is able to generate signals for 2 different motors (step and direction). Usually when you use stepper motors you need these 2 parameters which are basically the only ones you need to make the motors move. By using these 2 signals I want to move the robot I assembled in SolidWorks. I'll attach a image of the assambly if it works.
Thanks in advance
Juan
01-19-2012 11:03 AM
Hi bmjunar,
Here are some general links that might be helpful as you try to use Softmotion and SolidWorks:
http://zone.ni.com/devzone/cda/tut/p/id/9566
http://www.ni.com/virtualprototyping/training.htm
Best Regards,
