How do you fix contour move if it always stops on the third movement?
Hi, I've been trying to us contour move with my crio to move to set positions from a table, but it always stops on the third row and doesn't run any further...
I was wondering if anyone knew how to fix this issue.
(5,351 Views)
Hi Hideoutdoor,
What does it do when you finish those three moves - does your program keep running?  Do you get an error?
Also, feel free to post your code and/or the table you're using.  If you're going to post the code, try and simplify it down to the least complicated way to replicate your issue - can you replicate this behavior with just the contour move, or does it only happen when it's part of yoru larger program?
And definitely add anything else that might help me understand what's going on.
Julian R.
(5,319 Views)
