How do you high speed capture off an RTSI signal
I'm routing a pulse signal from an E series card at 200-500 Hz I want to trigger the 7344 motion card to high speed capture the position at each pulse from the DAQ card. How can I do this? Also is there anyway to buffer the position readings for analysis later? I've attached the code I've developed so far.
(3,077 Views)
Have you seen this exampl?
It should do exactly what you want!
Onboard Program - Continuous High Speed Capture into General Purpose Buffer
Amaury Rolin
NI Applications Engineer.
(3,077 Views)
