How to actuate 20 solenoid valves using labview
I want to perform an action of detaching materials from a fixture by actuating 20 pneumatic pistons controlled by 20 solenoid valves.
If the valve is actuated the piston moves and stays in the location for 1 sec and then return back. Each of these cylinders should be able to be controlled separately.
Kindly provide me with the necessary equipments i should buy.
How can i control 20 solenoids using a DAQ card.  is it possible?
Also i need to accept around 20 Digital Signals too.
Could you specify any card that will meet the spec.?
Thank you in advance.
Regards
grugh
Regards
Grugh Mike
Success is Everything !!
Message 1 of 1
(5,856 Views)
