01-23-2006 10:12 PM
01-24-2006 12:58 AM
01-24-2006
01:10 PM
- last edited on
04-23-2024
09:49 AM
by
Content Cleaner
Hi bkk -
The choice of accessory equipment will depend on the drive and feedback method you plan to use. If you would like to use an NI servomotor drive (the MID-7652 would be appropriate for your controller), the cable that will connect your controller and drive is the SHC68-C68-S. If you plan to use a third-party motor drive, you'll need a breakout unit to make the appropriate connections with your controller. The UMI-7772 is our two-axis breakout unit, and the same cable will connect to it.
