How to clear Error -70133 obtained during initialization of NI 7358 controller
While trying to initialize the NI 7358 motion controller, I keep getting the following error :
Error - 70133 (NIMC_pointRequestMissingError)
Internal error.  The internal points request buffer is missing a request.
I get this error only when I set the "control loop update period" greater than 500 microseconds in the NI-MAX control loop settings.
How can this error be rectified?
(3,204 Views)
Hi Jags,
    I'm not yet sure what the exact cause of this issue is, but I have a few things I would like you to do.  If you could go to our Motion Drivers page, NI-Motion 7.5, and install the latest motion driver (make sure you uninstall your card to install the driver), and then go into MAX and update the firmware.  Let me know if that yields any results, thank you!
-Allison S.
Calibration Services
Product Support Engineer
(3,187 Views)
