How to communicate with Compax3 via RS232
You send them from whatever device you need to send them from.  It could be a PC, HMI, PLC, etc.  If you are using a PC, you can do it from C3 Servo Manager's Optimization tool.
Message 21 of 88
(5,053 Views)
TWGomez used this command:
O 1100.3=$6203
$6203 is 0110001000000011 in binary
So he's got Bit 9 or Address 1 enabled.
What does enabling it do?
What do the addresses reference and what do bits 4 through 7 do?
The documentation doesn't say. Smiley Indifferent
Message 22 of 88
(4,978 Views)
Addresses refer to the stored moves.  Address 1 selects the first move.  Address 2 selects the second move.  If address 1 and 2 are on, then move 3 is selected, etc.  Bits 4-7 turn on the physical outputs of the drive.
Message 23 of 88
(4,971 Views)
Object 1100.3 is called control word. If you have a T40 Compax3 drive, it is fully programmable. You can use individual bits of the control word to do any job. For example, the "0 th" bit of control word 1100.3 can be used enable the MC_Power block, "1 st" bit can be used to enable the MC_MoveAbsolute block and so on...
If the drive is T11 or T10 Compax3 drive, you cannot program it. In this case the control word has fixed factory settings for each bit.
Bit0 - Quit (edge) / energize axis (Equal to Digital Input 0)
Bit1 - No Stop (Equal to Digital Input 1)
Bit2 - Jog + (Equal to Digital Input 2)
Bit3 - Jog - (Equal to Digital Input 3)
Bit4 - enable output0
Bit5 - enable output1
Bit6 - enable output2
Bit7 - enable output3
Bit8 - Address0
Bit9 - Address1
Bit10 - Address2
Bit11 - Address3
Bit12 - Address4
Bit 13 - Start (Edge)
Bit14 - No Stop (2nd Stop)
Bit15 - Brake open
Similarly, there are two Status Words (o1000.3 and o1000.4) which can be used to read specific and programmable(only some) bits. Read the T11 manual from the C3ServoManager Help or CD.
-vijay.
-Regards,
Vijay,
Application Engineer,
Parker Hannifin.
Message 24 of 88
(4,967 Views)
Vijay is correct on the addresses.  They are zero-based, not one-based as I stated.
Message 25 of 88
(4,963 Views)
Thanks everyone.
If I don't have any stored moves must I still use bit 8 through 12?
What I am trying to do is make a Labview program that allows the user to modify
O 1901 (position)
O 1902 (speed)
O 1905 (mode)
O 1906 (acceleration)
O 1907 (deceleration/denominator)
O 1908 (jerk)
For each mode. O 1901.1 for MoveAbs, O 1901.2 for MoveRel etc..
The example code from earlier in the thread ended their script with:
"O 1100.3=$6203" (Sets the appropriate bits to move the axis)
-TWGomez
or
'O 1100.3=$6503'
-jpatrickuci
Both of thesehave addresses set to 1. I have yet seen an example where all the addresses are set to 0. Which is why I'm wondering if it is necessary or not. Since I dont' have any moves stored and just want to run the motor continuously at the settings the user sets.
Does Jog+ set the motor to run continuously?
Thanks again
Message 26 of 88
(4,954 Views)
Looking at the Status Diagram on 5.1 of the manual.
 It looks like Jog and and Contiunous Motion are 2 different things.
I will try to get continuous motion working rather than rely on jog.
This, I think, will require me to use the Velocity mode.
Message 27 of 88
(4,941 Views)
Jogging is manual motion. Move absolute and move relative or move additive are discrete motion modes. Move velociy is continuous motion mode.
As long as you keep pressing jog + or jog -, you can have motion.
To stop it, just release the jog button!
Simple and clean!
-Regards,
Vijay,
Parker Hannifin.
Message 28 of 88
(4,928 Views)
Yeah, but as a serial command. I thought I could set it to jog+ and it would just jog but apparently it doesn't work that way :]
I'm currently having the same trouble as TWGomez from the first page of this thread.
In that, writing and reading objects work. I can set an object to have a value and afterwards, read back that value.
The thing though is that the motor doesn't react. I set O 1100.3 = 1 to energize the axis and it doesn't.
In setup mode, I can energize it just fine, I press the button and I can hear it humm. When I send this commandword it doesn't do that.
My compax3 is a T11 not a T30 like TWGomez's if that makes any difference.
Message 29 of 88
(4,918 Views)
I12T11?
Message 30 of 88
(4,916 Views)
