How to programatically very the PWM output frequency in 7344, to the desired value
Hi
I can use the PWM output only for the frequencies that is specified like 40Khz or 20KHz. I require to set the PWM frequency programatically to the desired value at a aduty cycle of 50%. How to implement this.
(2,904 Views)
What exactly do you need the PWM oututs for? Are you using a motion drive that requires a PWM command? The controller itself does not allow you to use the PWM ouputs to change the frequency on the fly. You might want to go to a DAQ board of Fielpoint moduel for this functionality.l
(2,904 Views)
