How to syncronize 5102 and 7352 with RTSI
Hi
I want to Capture the encoder 1 and encoder 2 position on my 7352 Motion Card when a signal on 5102 (ch0) reach a predefined trigger level (set by software). I think the best way will be with the rtsi lines but nothing will work. Can anyone please give med a labview example so i can get it work. I asume that i shall connect the rtsi lines on 7352 and 5102 to each other.
Best regards
Rune Gundersen
(3,058 Views)
Rune,
Here is the default location for the LabVIEW example:
C:\Program Files\National Instruments\LabVIEW 7.1\examples\Motion\FlexMotion\Buffered Breakpoints and HS Capture.llb
One thing to note is that you need to configure the HSC input to be routed from the RTSI connector. YOu can do this with the Select Signal VI or in MAX.
Rodger S.
(3,055 Views)
