12-23-2010 01:22 PM
I have designed a simple gear set-up in solidworks. My first gear is connected to the rotary motor and the second gear is mated to the first one. When using softmotion functions, the gearing has a master axis and a numerator and denominator. I don't know what to connect to what and how?
Attached is a word file with my print screens.
12-24-2010 07:55 AM
The gearing function block is for multiple axes. It "electronically" gears 2 or more axes together. Instead of have a driveshaft between 2 axes, the gearing function block is used.
12-24-2010 08:01 AM
Are there any examples that i can look at because i'm not sure I understand
12-24-2010 11:54 AM
You need 2 axes to use the gearing function block. The master and the slave(resource). The function block allows one or more axes to follow a master axis. Not sure about the NI stuff, but a master can be another motor, just an encoder, or a virtual axis. This function block has nothing to do with physical gears.
12-27-2010 09:32 AM
joseph.davidow,
As Brian mentioned the gearing function in softmotion can be thought of as a virtual gear. It allows you to control one axis relative to another.
Say for example you have 2 motors and you always want axis 2 to spin twice as fast as axis 1. You can use the gearing function in soft motion to create a 'virtual' 1:2 gear between axis 1 and 2. Then you only need to create a motion trajectories for axis 1 and axis 2 will automatically be driven at twice the speed of axis 1.
Please let us know if you have any more questions.
Sam K
