12-14-2010 01:51 PM
We want to put the actuator in a vessel with diameter of 9''and fix it to the flat bottom vertically.
Also the actuator should be in the center axis of the vessel. The active end of the actuator will be
connected to our sample holder which we can design according to the actuator.
Now we want to control it to realize reciprocating motion.
For example:
1) go up to15'' and hold 30 min;
2) go down to 5'' and hold 15min;
3) repeat 1) and 2) 50 times.
Vessel Pressure: 150psi; Temperature: 50-70℃(estimate)
12-15-2010 11:10 PM
Hey Li,
Check this site Stage Advisor, for a list of motors that will travel at least 15'' and that are compatible with our Motion Controllers.
You can always just go to the Advisors for Motion to change the specs you want to look for.
Hope this helps!
12-16-2010 09:09 AM
If we buy the linear actuator K2P2.0G10-12V-BR-18 from Warner Company. The actuator can provide a 0-10VDC signal as feed back for position control, what PLC can compatable with this actuator? The attachment is the PDF file of the actuator hookup
with the P2.0 actuator option. Please review page 2.
12-19-2010 11:40 PM
Hey Li,
What form factor are you looking for? PCI, PXI, or CompactRIO?
Alex Z.
