I can't run the stepper motor using NI 9501 with the example given.
hello
I am succesfuly able to control a single motor.Can you tell me how can I control 2 or more motors at the same time with NI 9501 and copac rio 9074??
Message 11 of 13
(3,097 Views)
I have everything working smoothly and no errors or faults but the motor isnt moving.  Is it supposed to move at all?
Daniel
Message 12 of 13
(3,070 Views)
I am new to cRIO.  I have moved the RT and FPGA VIs into the appropriate positions but only the FPGA VI is executable.  I have no control over the motor using this VI.  On the other hand, the RT VI has control station - but I have many errors in the VI in the block diagram.  When I want to control the motor, it looks like you use the RT VI.
Obviously I am not understanding something here with the cRIO or perhaps I copied over the files incorrectly.  But can someone give me some guidance regarding these concerns?
I have a 5lead stepper all hooked up and I want to try and control it.
Daniel
Message 13 of 13
(3,064 Views)
