I can't seem to find a labview driver for the product REL-230-18;
I have a controller made jointly by Harmonic Driver and Copley Controls. I will be controling it through my serial port. I can't seem to find any labview driver for it. Anyone know if I can find one or if there's one available for a similar product that might work? Thank you.
(5,766 Views)
Hi there. I also did a quick search but could not find anything, nevertheless, the REL-230-18 can be controlled through the serial port by sending VISA commands. Look for the manual, you only need to know what commands (and the syntax) this instruments can take in order to build your application. The basic serial communication example that is located at the NI example FInder should provide a starting point for the programming. I hope this helps
Alejandro C. | National Instruments
(5,754 Views)
