I can't use autotuning with MAX, because it puts high gains in the PID.
Which are the rules to use the autotuning in Max?
(2,950 Views)
Thank you for contacting National Instruments. Autotune works well for most systems given the axis parameters are configured properly. In cases where Autotune doesn't seem to work properly you'll need to manually tune the motor. See the following tutorial regarding information on manual tuning: http://zone.ni.com/devzone/conceptd.nsf/webmain/4B7775373E4AE64986256B6000691505?opendocument
Hope this helps! Let me know if you have further questions regarding this.
Yusuf Cavdarli
(2,950 Views)
