I get a build error (Error 1052) while trying to compile one of the motion example vis in Labview 2009.
It seems that the error occurs when I try to use one of the motion vis such as Load Velocity.flx etc. Has anyone had this kind of problem ? Thanks for any suggestions.
(4,363 Views)
Hi Neko3422,
Do you have any VIs in your program that has a slash name (such as Load  Acceleration/Deceleration.flx)?  There is an issue in LabVIEW 2009 (#158487) where this build error occurs from file names that have slashes.  Try checking "Use LabVIEW 8.x File Layout" in the Advanced category under Build Specifications to see if this fixes the issue.
(4,353 Views)
Hi Kyle,
Thanks for your advice. It did solve my problem.
Neko3422
(4,337 Views)
