I need to use LabView 6.x to write a character string to a motor controller for a linear actuator via the serial port.
I have tried to use the VISA Write command, but the results have not been fruitful. Any example vi's could be helpful.
(4,313 Views)
There are several examples that use the serial VISA commands that ship with LabVIEW 6i. If you select "Search Examples" from the LabVIEW splash screen, or "Help -> Examples" from the pulldown menu, you will have access to our examples browser.
By selecting "I/O Interfaces" and "Serial Communication" you will see the three serial examples that ship with LabVIEW. Additional examples are available in the Developer Zone at http://zone.ni.com.
(4,313 Views)
Dear Jon,
I think you have to send the ASCII string to your controller.DO FOLLOWING THINGS.
1) CONFIRM THAT YOUR CONTROLLER SUPPORTS ASCII COMMUNICATION.
2) CONFIRM PIN CONFIGRATION OF YOUR CONTROLLER.THE PIN CONF OF PC SERIAL PORT IS 2-RX 3-TX 5-COM. MAKE A CABLE RX-TX , TX-RX & COM-COM.
3) USE SERIAL PORT VIS
INT PORT, WRT PORT ETC.
ALL THE BEST
SURENDER SINGH
(4,313 Views)
