I want to control servo value from PCI-7344+Flexmotion with 20 Hz Sine/Triangle wave as command and anlog feedback Help me in doing so
Under Trajectory generation and Buffered programming section of Flexmotion i found that interval between 2 points is limited to minimum of 10 msec.To generate & control 20 Hz waveform any other alternative approach is available ?
(3,926 Views)
For buffered programming the minimum rate is 10msec, so the best you will be able to do is 5 points per period. This should be enough to give you the general shape of the wave, but it is not going to be as smooth as you might like.
(3,926 Views)
YOu can also configure an axis for gearing and have its master be an ADC, you can then input your 20Hz waveform into the analog input and the slave axis will follow its trajectory better.
(3,926 Views)
i have a problem:
i have configured an axis for gearing and have its master be an ADC, when the analog input is more than 30Hz,the slave axis can't follow up the master,is there a method to solve the problem?
(3,543 Views)
I have posted an answer to this question in this thread.
Jochen
(3,493 Views)
