Illegal board iD error for PCI-7354
Hi everyone,
I have a system based on LabVIEW Real Time 10.0f2 with a PCI-7354 built in 2009, running until last week.
Now the controller stops working at the initialization of the four axis. We replaced everything after the PCI-7354, axis, cables etc. It seems the PCI-card is broken.
I have a working replacement here from another system. If I swap the cards I got an error 70012 "Motion: Illegal board ID. You must use the board ID assigned to your controller in Measurement & Automation Explorer."
Is there any way to use the replacement card without rebuilding the operating system?
I don't have experience with Labview at all and it seems we don't have all the sources/software to rebuild the operating system
Best
Sven
(1,940 Views)
Launch "Measurement And Automation Explorer" and change the board ID according to the Motion configuration.
(1,926 Views)
Good morning, thank you for your reply.
Thank you for the hint to MAX. But why is the PCI-7354 not visible at devices? It looks the same for the broken system and for two working systems with same configuration. (PCI-6733 + PCI-7354)
Best
Sven
(1,885 Views)
