In LabVIEW, how can I address a digital output line in a NI7350 board?
Thank you, Ivo
(4,309 Views)
In the NI-Motion palette go to Analog & Digital IO and select the "Set I/O Port MOMO.flx" vi.
Here is a paragraph from the online help:
The Set I/O Port MOMO VI sets the logical state of bits in the general-purpose I/O port selected.
Using the Must On/Must Off protocol allows you to set or reset individual bits without affecting other output bits in the port. This gives you tri-state control over each bit: on, off or unchanged. A True in a bit location of the Must On bitmap turns the bit on, while a True in the corresponding location of the Must Off bitmap turns the bit off. A False in either bitmap has no effect, so leaving both the Must On and Must Off bits at zero is effectively a hold and the state of the bit is unchanged. If you set both the Must On and Must Off bits to True, it is interpreted as a Must On condition and the bit is turned on.
I hope that helps,
Jochen Klier
National Instruments Germany
(4,301 Views)
I am looking to do the same thing with my 7356 controller.
Looking over the FlexMotion VI's though, it seems that I won't be able to mix lines within a port to have some as input and some as output.
For example - what I was hoping to do was use Port 1 Lines 0, 1, 2, 3 for output to a fluid valve for 4-line BCD control and monitor Port 1 Lines 4 and 5 as output from the valve (which would be input to the board).
Am I restricted to using all the lines in a general digital IO port on the motion card in one direction?
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(4,165 Views)
You can define the digital line direction bit-wise with flex_set_port_pol() or in LabVIEW with the Set I/O Port Polarity vi. Please refer to the corresponding information in the help file for more information.
Jochen Klier
(4,146 Views)
I must be totally misunderstanding the use of this VI then, as I do not read the help file to indicate that it controls whether the line direction is input or output - only whether it inverts the signal on the line.
(4,143 Views)
Oops, I'm awefully sorry but I have mixed up the function calls. Of course the correct function call is flex_set_port_direction() and the corresponding vi is Set I/O Port Direction.flx.
Sorry again for the mistake.
Jochen
Message Edited by Jochen on 09-11-2006 03:49 PM
(4,140 Views)
