Industry standard for CNC script?
Dear All,
Is there some kind of industry standard on "CNC-type motion control script".
Basically, the user script will be lines of text
Each line is    OP-CODE    Parameter0   Parameter1 ...
Like        MOVE_TO 123.45 345.67
and our software will parse the text and generate the corresponding command for the NI motion controller card.
e.g. the user-entered parameter 123.45mm will be converted to number of pulses.
Some poster mentioned G-Code, what is that?
(4,208 Views)
Hey John_,
I would recommend that you check out the following discussion forum posts:
- How to use CNC G-CODES and M-CODES in LabVIEW
- Has anybody used motion control card like a CNC contol with G-codes with part program editor?
- can you send me the gcode interpretor for the pci-7334,7344.. thanks
These are just a few threads that discuss what you are asking about, but there are a few more out there if you do a search on "CNC Motion"
I hope this helps. Please let us know if you have any further questions or concerns.
DJ L.
(4,185 Views)
Hi John,
G-codes, M-codes and T-codes are used to give commands to a CNC. You can easily parse these codes in LabVIEW, but there are thousands of features that a CNC has, implementing which is not too easy. What is your application. Is it an SPM, Lathe, Milling machine or something else. I have been working on this for 7 months now and have been able to make a medium featured CNC out of labview. Full featured one may take a few years. I can guide you on this. Let me know more abt. your application. I'll can send you the list of G-codes and M-codes with functionality if you want.
Giridhar Rajan
Automation Engineer
Cruiser Controls
Mumbai, India
(4,178 Views)
Hi Mumbai,
We are doing simple XYZ motion control. Not really CNC. Just want to borrow the cnc-style G-code.
(4,171 Views)
