Interface between bnc2110 and m series 6259
hi,
i got some Questions and i need help urgently.
i am using M series 6259 and BNC 2110 for my project.
Q1. why when i configure one of the digital I/O as output and drive my motor. the out voltage from the I/o port  read 5 volts but when i connected the I/O port to the red and black terminals of the dc motor. The measured voltage at the DC motor using muti meter is only 3v? Is there any way to increase the voltage to 5V so to drive my dc motor.
Q2. when i configure the analog I/O to be output for BNC 2110, make it 5V at the terminal. But when i connected it to my motor, the motor does not rotate? why?
Q3. I am using a stepper motor to control the rotation of a turn table, in addition sensors are used to stop at desire position. the turn table will rotate at a interval of 90 degrees and using the IR sensors to stop. is it possible to use 6259 to generate signals and thus control the stepper motor with BNC 2110? and detect the sensors? is it ok to give me some pointers? or any reference VI so i can work on it?
4. I am think of using the time loop function of lab view for my application. is it ok? is there any tutorials on it?  or is there better ways for me to do it? like sequence?
thanks guys... hope to hear from you all soon...
thanks again.
(3,463 Views)
as it was already mentioned in your other thread, a DAQ-board is really not a good fit for your application. For more information about the reasons and better alternatives, please look here and here.
Kind regards,
Jochen Klier
(3,460 Views)
