Invert axis output?
Is there a way to invert the output from an axis? I'm summing the outputs from Axes 5 and 7 using an op amp on a PCB I designed. But the load cell I'm using as the feedback for Axis 5 outputs the negative of the voltage that I want. Can I invert the signal in MAX without needing to add an inverting op amp on my PCB?
Hardware: PXI-7358
LabVIEW 2010
Axis 5 feedback = analog output load cell, Axis 7 feedback = motor encoder
Matthew
(5,670 Views)
You can connect that signal to your drive with reverse polarity. That will invert the output. Otherwise, you may need to use an inverter.
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(5,656 Views)
