Is LW7 linear stage motor connectable to PCI-7344 controller?
I am new in motion control. I am planning to build an inspection system in which the linear motor can find the address of the regular dent, located on a specific bar. The linear motor has to be connected to 7344 series, and the software is made with LabVIEW.
As NI introduced many motor brands, I am wondering if the LW7(Anorad) is connectable to PCI-7344 series motion controller. LW7 motor is shown in:
http://www.anorad.com/onlineCatalog/linear.htm
http://www.anorad.com/onlineCatalog/electrical.htm
(4,174 Views)
As long as the drive that you are looking at runs in torque mode, has only a current feedback (ie does not conflict with the position feedback of the 7344), and can output a regular encoder signal, you should be fine.
(4,174 Views)
