Is it possible to micro step using the Pci7314 (open loop) controller and umi7764 and Labview.
Is it possible to micro step using the Pci7314 (open loop) controller, umi7764 and Labview. if so how would this be set up. i have searched the valuemotion vi libraries and found no microstepping functions. Please could you offer any advice. cheers JON ROGERS
(4,755 Views)
Hi Jon,
Micro-stepping is a property of the motor amplifier (motor drive) rather than the controller. It sounds like you are using a 3rd party drive, since you have a UMI. You want to check with your motor amplifier documentation to see if it's supported. Usually, there will be dip-switches on the drive that sets the microstep factor.
Hope this helps. Please let me know if you have any questions.
Ken Sun
Applications Engineering
(4,755 Views)
