Is it possible to use angular targets PCI-7342?
I have a system that control motion of a test platform that is rotated around the axis of the motor shaft.
Hardware: PCI-7342 to handle motion control - with the UMI-7764, PCi-6229 for angular position measurements
It is a quadrature encoder with Z index output.
I'm wondering how the PCI-7342 would receive target commands in absolute position mode, and how the Z pulse alters the position tracking on the 7342 (even though we're reading position for plotting to GUI from the 6229 - I know how that is going to work).
The home is the 0 angular position, and lets say the target is 90 degree CW (with CW being the positive directions for counting the encoder pulses).  Lets say Counts/rev = X
To move to 90 I would have to set the target position = 90 * (Counts/rev)?
If I want to move -90 (or 90 CCW from 0) would I send it -90 * (Count/rev)?
What about when I want to travel to 360? do I set the target at  (Counts/rev) - in this case - does the Index marker reset the count on the 7342 to zero (or whatever value I tell it)?
Let me know if you need more information on this.
Thank you,
Ryan
Message Edited by RVallieu on 11-18-2005 01:42 PM
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(3,392 Views)
Hello Ryan,
Try to set target position Target deg (counts/deg) i.e. target 90deg and counts/rev are 4096 then 90*(4096/360). The marker pulse would not reset the readings.
The absolute mode is like if you move 0 to 160deg and then you set  target 80 deg then the axis will come back to 80 deg it will not move further 80 deg means 160+80=240 deg.
I hope it may help you.
(3,363 Views)
Thank you for the reply - that is what I figured it would be, I was just uncertain if the Z - index pulse reset the counter on the 7342.
I would just have tested it and seen for myself but the equipment is at the customer site and not finished assembly yet.
Ryan
(3,360 Views)
