Is there a seperate software for stepper motor control or is there a motion control toolbox that is added to LabVIEW 6i?
I have LabVIEW 6i and I intend to use appropriate cards, and Flexmotion driver for stepper motor control,Do I need to load a seperate software other than LabVIEW for stepper motor control,Is the software available as a function tool box that can be added in LabVIEW 6i. If there is a seperate software then I would like to know the cost of the software, Cards etc.
(4,030 Views)
The Flexmotion Driver provides all of the software needed for your hardware, as well as all of the software needed to write motion applications in LabVIEW. When you install the Flex Motion Driver, it should install a Motion and Vision Palette in LabVIEW that contains all of the functions. The driver is provided with our hardware and is available for free download from our website. I hope this helps....
Chris D
NI Applications Engineer
(4,030 Views)
