Limit Switches Disable All Motion
I am using LabVIEW 2009 SP1 with a cRIO and the 9512 Drive Interface Module.
When I contact my forward and reverse limits during regular motion, the motion stops and I am not able to continue any more motion in either direction.  It works fine when I am performing a reference move, however.  I am receiving error codes -70225 and -77025 saying that a limit has been triggered.  When I use the Interactive Test Panel, I do not have any issues with moving the opposite direction after a limit is triggered.  Has anyone else ran into this problem?  Is there any way to configure the limit switch options?
I have looked in MAX as suggested on some older threads but my module doesn't show up in MAX...
Justin
(4,376 Views)
This is a known issue that is being worked on under Corrective Action Request #200776. I would suggest that your best workaround would be to programmatically check for the error and then reexecute the proper code when it is thrown.
-Zach
(4,364 Views)
I reached a temporary workaround.  I had tried to clear errors from the axis but had no success.  I realized that the axis (not the drive) was being disabled so I needed to ensure that the axis was enabled before each move.  I accomplished this using a power on function block enabling the axis and drive before each move/jog command.
(4,331 Views)
