Limit and home switches are active
I have active limit and home switches as indicated in the screenshot below. Can anyone help find out how to get the lights turned off?
Thanks!
(1,797 Views)
I have not worked with the NI MAX for a while, but I think it is possible to disable all limit and home switches somewhere in the setup for the axis in question. Also, it is possible to change the limit switch inputs from active high to active low and vice-versa. Depending on the type and wiring of limit/home switches you are using you have to set them to proper "polarity", otherwise they may seem active while they actually are not activated.
(1,770 Views)
Are any signals connected to these inputs ?
(1,766 Views)
