Linearmotor not running
I have got a (4 pieces) linearmotor and have to use it with the PCI7350. When I disable the inhibit output, I can enable the Motor with a simple LV program and can swith the controller into the current mode (for usage with ADC). If I enable/disable the inhibit output I can not use the servo tune in Measurment and Automation Explorer.
What is wrong?
Best regards
Andy
linearmotor (LinMot PS01-37x240-C)
Controller LinMot B1100-V (Current Mode) connected to UMI7764 with a voltage converter
2x UMI7764
PCI7350
LV2011
M&A Explorer 5.0.0f1
NI Motion 8.3
Best Regards,
Andy
_____________________
PCI-7356@UMI7764; PCIe-6320@SCB-68; LV2011; Motion Assistant 2.7; NI Motion 8.3; DAQmx 9.4; Win7
(5,837 Views)
Accepted by topic author AndySchütte
Hey,
grr. Beginner's mistake. I had to save and initialise the motion controller after switched the inhibit polarity.
Best regards.
Andy
Best Regards,
Andy
(5,787 Views)
Hey,
Best regards.
Andy
Best Regards,
Andy
(5,787 Views)
