MAXON EPOS 4 control using embedded CAN for RIO
I am trying to control a MAXON EPOS 4 BLDC drive using a single board Rio and the embedded CAN for RIO library. I think I am close, but I am not quite sure whether my formatting of the data payloads is correct.
Sending a simple PDO message like Reset (x81 followed by the node address) seems to work fine, however I am not sure whether I am successfully sending more complex messages as PDOs or whether I need to implement this using CANopen SDO objects.
The MAXON device programming document seems to outline the minimum amount of commands I need to command rotation.
https://www.maxonmotor.com/medias/sys_master/root/8830265196574/EPOS-Application-Note-Device-Program...
Do my payloads need to be formatted as follows:
COBID, special byte, Index low byte, Index high byte, Sub-index, data
So for example, to set the operation mode, the payload might be;
x06 01 23 (special byte), 60 60 00 01 (Profile position mode)
Does the identifier need to be set to anything? I have just set it to zero when sending the reset command.
If I follow this methodology for formatting the payloads and send the controller all of the commands in one of the device programming examples, will I be able to command some kind of motion?
(3,238 Views)
Is it necessary to use CANopen with the MAXON EPOS 4?
If it is, the recommended way of implementation CANOpen communication on sbRIO is to use NI-9881 module with the corresponding RMC daughter card see this post(https://forums.ni.com/t5/Automotive-and-Embedded-Networks/How-do-I-setup-a-sbRIO-9607-to-use-a-9881-...).
Note that DIO will be consumed.
If using RMC daughter card is not fit, implement the CANOpen protocol based on the NI-CAN driver. You can use the existing examples of CANOpen implementations based on CAN.
CANopen Reference Example for the NI-9853 C-Series CAN Module https://forums.ni.com/t5/Example-Code/CANopen-Reference-Example-for-the-NI-9853-C-Series-CAN-Module/...
Hope this helps!
(3,196 Views)
