MID-7604 limits and inhibits
Good Afternoon,
I have had an open loop stepper system working for the past couple of years.  It recently stopped working. I cannot get any motors to move.  Inhibits LED #1 is always lit and the other three Inhibits LEDs are always dark.  I have removed all connections from the back of the MID-7604 except for the AC power and the NI cable connecting to the 7344 PCI board.  After initialization, Limits LED #1 is lit and the other three Limits LEDs are dark.  I am using the MAX default open loop stepper configuration.  When using the 1D interactive tool in MAX I am seeing the following behavior:
Axis #4 Kill --- Limits LED #2 Lit
Axis #4 Start --- Limits LED #2 Dark
Axis #3 Kill --- Limits LED #3 Lit
Axis #3 Start --- Limits LED #3 Dark
Axis #2 Kill --- Limits LED #4 Lit
Axis #2 Start --- Limits LED #4 Dark
Axis #1 Kill --- No change
Axis #1 Start --- No change
Limits LED #1 always remains lit.  Again, Inhibits LED #1 is always lit and the other three Inhibits LEDs are always dark regardless of any commands of any axis to kill or start.
I have tried a spare 7344 PCI board with no change.  Does this look like a defective MID-7604 and is there some other way to verify that?
Ed
(3,174 Views)
Hi edlad,
This sounds like a bad drive to me.  I would suggest giving NI a call.  We should be able to set up an RMA for you.  You can reach us by calling 1-866-275-6964.
Adam H
(3,148 Views)
