Motion Assistant 1.3
Recently I upgraded to NI-Motion 7.4 and Motion Assistant 1.3. After that I recompiled my Visual C++ application. My application uses Motion Assistant API to interpolate the coordinates for contour mode. After the upgrade, the Windows process of my application is no longer terminated after I close the application. This happens in release and debug versions and even while debugging the application using Visual C++. And it only happens if my application initializes the Motion Assistant API (NIMAOpenMoveHandle function). I’m calling NIMACloseMoveHandle at application exit.
Thanks.
Message 1 of 1
(3,825 Views)
