Motion Assistant Code Generation
I am using the Motion Assistant code generation tool to generate a simple single axis relative move in LabView.
In the Motion Assistant I can jog the motor CW or CCW, however it does not appear I have control over the rotation direction in the VI.
The LabView code works fine otherwise for all other parameters, I just need to be able to control the direction.
Can someone pointme inthe right direction?
Kevin
(5,917 Views)
Figured out the error of my ways....changing the sign of the distance number controls the rotation direction.
(5,915 Views)
