Motion Assistant won't accept ValuMotion controllers what can i do?
I have NI 7324 motion controller. Motion Assistant does not support Value Motion controllers. Are there any software updates available? Thank you
(3,148 Views)
Hello panggru,
Thank you for contacting National Instruments.
Unfortunately, as you mentioned, Motion Assistant does not support ValueMotion controllers. Our newer driver, NI-Motion (or FlexMotion), is not compatible with ValueMotion controllers. The latest release of ValueMotion is 5.0.2, and I do not anticipate any updates that will allow ValueMotion boards to work in Motion Assistant. However, ValueMotion does include a full API for programming your board in LabVIEW, C, and Visual Basic.
Best Regards,
Jesse D.
(3,148 Views)
