Motion Assistant
i am trying to use Motion assistant 1.02 version to develop my application. i am not able to generate code in labveiw for the option generate operation is disabled . please let me know what is the problem my software is licenced one
(3,556 Views)
Suresh,
the only reason why you couldn't create LV code from within the Motion Assistant I could think of could be the fact that you either don't have LabVIEW installed on the PC or that your LabVIEW version is too old. You need at least LabVIEW 6.1 on the PC where the Motion Assistant is installed in order to be able to generate LabVIEW code.
Jochen Klier
Applications Engineering Group Leader
National Instruments Germany
(3,556 Views)
Hai,
I have lab veiw 7.o express installed in my PC . please note i can generate code for only the exampl programs give by NI . please tell me why i cant generate LV Code. I dont have a motion Card . can i generate using virtual cards. I have a licenced copy of motion assistant
with regards,
Suresh Thangappan
Application Engineer,
Captronic Systems( NI alliance Member)
(3,556 Views)
Hi, Suresh,
Yes, you should be able to generate LabVIEW code from Motion Assistant when using virtual motion controllers.
Are you using a virtual 7358 motion controller? If so, this might be part of the problem. Motion 1.0.2 was released just before NI-Motion 6.0 and the 735x series controllers. For this reason, when generating LabVIEW code from Motion Assistant when axis 7 or axis 8 of the 7358 controller is being used for the move, the code generation will stop just before the first time these axes would be used.
If this is not the case, my only other suggestion is to do a repair or reinstall of Motion Assistant. If this does not resolve the issue, please contact National Instruments technical support for further troubleshooting.
Best
regards,
D. Putnam
(3,555 Views)
