Motion Control using TRIO MC403 P825
Hi Everybody,
            Here i need some help to interface TRIO MC403 motion controller with labview but i don't see any drivers related to this product, i need some suggestions on this.
Thank you,
Dinesh
(2,835 Views)
Hi
There are no drivers readily available for TRIO controllers in LabVIEW.
The TRIO motion controller setup provides .ocx file. This is accessible in LabVIEW through activex.
(2,672 Views)
Hi sir,
  Thank you so much for replying me back
   Actually i've already found a solution to take control of trio using Activex control in labview but still i was facing some issues in accessing the commands, till now i am able to send the command asynchronously through labview.
         In this method i can access only two commands,
         1. Send data
         2. Get data
         In between there is no other command is working, is that any communication issue or any other issues?
. I've attached you a software reference manual with this,  tell me if there is any possible solutions.
Dinesh
(2,665 Views)
