Motion assistant 2.1 code generation...
HI all!
I have a problem generating labview code with motion assistant 2.1 ; My labview version is 8.2.1 and I've tried all manner of installs / uninstalls combinations trying to get it to generate labview code. It consistantly gives me the error: Labview templates not found when I try to generate...
Any info would be appreciated!
(3,249 Views)
Thank you for using the NI discussion forums.  It sounds like the problem may be with the NI motion driver.  Have you installed the NI-Motion driver?  This is seperate from the motion assistant.  Once this is installed then you should see that error go away.  If you do have that installed what version are you using? Did you install NI Motion after LabVIEW?  If you did it before installing LabVIEW you may have not included LabVIEW support, which can be corrected by modifying the installation.   I hope this helps.
Have a great day,
GG
(3,233 Views)
