Motor Control MID-7654 PCI-7340
I'm configuring MAX settings for a servo motor with an embedded quadrature encoder.  I set up the motor on Axis-1 and I'm simply trying to drive the motor without a load.
The motor has been able to drive under stepper motor settings, but the move is jerky and I don't have access to the encoder feedback.  When I configure the motor as a servo, the encoder feedback is working properly.
Does anyone have any suggestions as to what to try?
Thanks!
-Erin
(4,269 Views)
climber_girl:
Not sure I understand your post- you have a servo, and when configured as a servo the feedback works.
Why then are you trying to set it up as a stepper?
-AK2DM
(4,264 Views)
Accepted by topic author climber_girl
That original post was slightly confusing.
I meant to say that the servo doesn't drive under the "servo" settings in MAX.  It wasn't getting a power supply.
However, I applied a load to the motor and started tinkering with the PID settings and it began working (still slightly jerky).  I think I answered my own question...
Thanks anyway!
(4,260 Views)
