Motor DC control
Hello
I want to control a DC motor 100W, using an USB6002 + labview 2012, and, I have been reading I will need an arduino tech but I not have experience in it.
I kindly ask you if I could control only with the USB6002 or I will need another NI hardware?
(2,764 Views)
Hello Betsabé,
What you need is a speed control for that motor, regardless of whether you are going to control it with the USB6002 or with the arduino.
If you use the USB6002 make sure the speed control inputs are compatible with the USB card outputs.
(2,666 Views)
Thank you Antoniooh so much
(2,626 Views)
